2016-11-28 07:58 PM
2016-11-30 06:44 PM
2016-12-01 04:38 AM
fuzzytnth3 wrote:I don't think you need to publish as modules.
Then Publish each of the Sub Buildings as Modules.
2016-12-06 01:48 PM
Barry wrote:You are correct, you can do that but I prefer not to do that as it can bring into the other Project file a bunch of stuff such as Composites, Fills line types etc that are not required by the receiving file.fuzzytnth3 wrote:I don't think you need to publish as modules.
You can hotlink a PLN directly into your master plan.
But as fuzzytnth3 said make sure you hotlink in the separate stories and not as a multi-storey hotlink.
2021-11-03 10:12 PM
For the sub buildings how do you "publish as modules", and is that a way to show the story levels of the module and not the story levels of the main .pln? For instance can I publish a pdf of building section for the sub building showing it's own story levels? Thanks
2021-11-04 02:59 AM
For a couple of sections on one job I did that cut through two buildings I turned off the story levels and linked in views with each buildings individual story structure. Might not be the best way to do it, but it worked.
Ling.
| AC22-29 AUS 3200 | Help Those Help You - Add a Signature |
| Self-taught, bend it till it breaks | Creating a Thread |
| Win11 | i9 10850K | 64GB | RX6600 | Win11 | R5 2600 | 16GB | GTX1660 |
