Geometry Fixer Macro
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
2023-05-31
02:46 AM
- last edited on
2023-05-31
01:40 PM
by
Rubia Torres
It would be helpful to have a macro that could "regularize" objects to a defined grid increment. No matter how judiciously a model is constructed, a mispositioned wall or other elements can create havoc in an otherwise orderly model. For instance, if the reference line of walls. slab, roof, trim, etc, are all supposed to be on a defined grid, but are off by a small but annoying fractional amount, it would be helpful to select the group of elements and then pick "adjust to nearest grid point".
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2023-05-31 02:56 AM
Are you aware of the 'Distribute' command?
If the first and last elements are in the correct position, you can select those and other elements in between.
Distribute will then spread them out evenly.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2023-05-31 04:53 AM
That is an interesting concept. Exactly how would that approach work with elements such as multi-segment walls, polygonal slabs and roofs though?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2023-05-31 05:16 AM - edited 2023-05-31 05:16 AM
For elements like walls and columns that you just want to distribute to an even spacing, it will be fine.
Note, they are not snapping to the grids - just being distributed equally.
For irregular shape elements like slabs and roof, I don't think you would be distributing them.
More like aligning their edge to a grid?
But there is a 'special distribute' that allows you to pick a point on the bounding box of the elements, and then draw a line to represent the distribution length and position.
