License Delivery maintenance is expected to occur on Saturday, November 30, between 8 AM and 11 AM CET. This may cause a short 3-hours outage in which license-related tasks: license key upload, download, update, SSA validation, access to the license pool and Graphisoft ID authentication may not function properly. We apologize for any inconvenience.
Give sketchup surfaces different texture in ArchiCAD
I got a complex sketchup model of the build environment around my ArchiCAD project. I now would like to make some renders in ArchiCAD using the CineRender engine. However, the textures of the sketchup file are really unrealistic. I'd like a more realistic texture, for example for the grass and bricks. Is there a way to paint them with a ArchiCAD texture? I tried the paint bucket but it doesn't work on skp files merged into the project...
Best regards,
Vincent
2 REPLIES 2
I don't know if there is another way, but the way I know to do this is converting the SKP model to morph and paint. Later you can save it as an library object.
That's exactly what I needed! Thanks!
