2022-03-18 04:04 PM
I am bringing an old Archicad 11 Project back to life as we have been tasked with re-cladding the Building and so need to edit a lot of the original Details.
What I have discovered is that a Label object I made as a poor mans Keynote tool uses a couple of Global Variables to find out the size of the label within the MasterScript.
Now it seems since Archicad 22 this is a bad thing. The other problem is the variable I called doesn't appear in the current Archicad 25 GDL Guide which means I assume I need to find out its new name.
The two variables giving me the issue are...
gs_label_width
gs_label_height
Any idea what these variables are now called as I haven't found them in the manual yet?
Thanks
2022-03-18 04:31 PM - edited 2022-03-18 04:32 PM
Oh argh, so my object was based on a Graphisoft Archicad 9 label object which I tweaked to suit what I wanted as it was good at handling changes of view scale and guess what it uses the variable "Glob_Scale" in the Master Script which the manual says you can't use as a parameter which obviously this label object does...
"I'm going to be sometime" as Captain Oates said
2022-03-18 05:00 PM
@fuzzytnth3 See if these pages help...
https://gdl.graphisoft.com/tips-and-tricks/labels-special-parameters
https://gdl.graphisoft.com/tips-and-tricks/new-parametrization-of-labels-for-archicad22
2022-03-21 10:03 AM
Thanks for those links. Looks like they could fix the problem. Fingers crossed.
