Help! - What are people using for insulation?
Unless I'm missing something, graphisoft's insulation symbols are basically worthless. This seems like such a simple thing so I think I must be missing it!? Please let me know where or what the proper 2d insulation object is.
Thanks.
4 Replies 4
TomWaltz
The batt insulation object? I use it all the time. What isn't it doing for you?
Tom Waltz
I was a little hasty with that one! - I only knew about the symbol in the detailer library, I just found the one in thermal and moisture protection, which works fine.
I don't recall which insulation object I was using, but there was a problem where if you use a bunch of them (like copying a segment at 16" o.c.), it dramatically slows down the regen time, and created very large PDF files. Just something to pay attention to.
Richard
AC26 (since AC6.0), Win10
TomWaltz
oh, man, you tried using the Detailer one? No wonder you were ticked...
Tom Waltz
