Help with railing tool in Archicad 21
I'm currently trying to use the railing tool on a staircase in a project. Whenever I place the railing it appears as a transparent material and doesn't fully solve any joints etc. How do I fix this?
Not too well versed on archicad as of yet but hoping someone's come across this before.
Thanks
1 Solution
Go to the Model View Options Dialog. In the "Stair and Railing Options" panel, check the setting in the "Railing Detail Level in 3D and Section" field. I think it is now set to "Simplified" whereas you should be setting it to "Full" to see the 3D model of Railings properly.
Please note that since this is a Model View Options setting and since Model View Options are saved with Views, whenever you activate a View this setting may change. So you should also check your saved Model View Options Combinations to see each contains the proper setting for this field.
Go to post
4 Replies 4
I am not really sure what the problem is exactly.
Could you post a screenshot or two that show the exact nature of the problem?
My apologies. Hope these two pics communicate the problem. Have changed railing finishes etc. but to no avail.
https://ibb.co/hzxBQx
https://ibb.co/juvLJH
Thanks again
Thank you very much, that's solved it. Lifesaver!
