Home story for doors and windows
I can set home story for wall or object but not for a door or a window. I can put a chair on 1. floor and assign 10th floor to it. Also, if a wall goes through two storys I can decide which is his Home story. But for door in that wall only its phisical location determines home story. For example, a bathroom door is 2 cm below 2 story level and in shedules it is listed in the 1 story, but wall is in 2 story. At least, I would expect that story of the door is determined by his wall.
Or am I missing some parameter?
12 REPLIES 12
Erika Epstein
Check the door's anchor. The door's sill should be referenced to the 2nd story, not the first.
"Sill to story 2"
Erika
Architect, Consultant
Mac OSX 10.11.1
AC5-18
Onuma System
That doesn't help. I have set Anchor Sill to 2. story but schedule still displays that door is on 1. floor. The wall is correctly on 2nd floor. As soon as Sill has negative number, it puts the door on a story below.
Erika Epstein
Luka,
You are right, when the insertion is a minus number, it puts the door on the lower story.
Why it the top of the 2nd floor slab, and so also the door, below the second story?
Erika
Mac OSX 10.11.1
AC5-18
Onuma System
Dont mind tha picture. This is just an example I made in few minutes to demostrate the problem.
Thank you Erica for verifying that I am not doing anything wrong.
The AC shows the right position regarding your defintion of floor level.
You have to do just one thing.
Correct the level of 2 story (+6,13 or lower). ctrl +7
For example the floor level for AC would be the structure level.
But be careful. It changes every construcktion parts depending on the level.
You can correct in any time the thickness of concrete slab very simply without changing the level.
In this case you must have separated layer for the floor finishing.
Link
When it comes to windows and doors, it's all about the anchor. Whatever story the anchor virtually resides in dictates what will be listed. Change your door to anchor by the header and you'll be fine. Other elements are based on the home story.
Link.
Link.
That is better way.
How didn't I think of that?
Thank you all.
Gerald D Lock
I now have the same problem many, many years later in AC23. Setting the anchor (Sill or Head) to the desired Story doesn't work.
Surely there is a way to force this - it's killing my schedule!!!!
ArchiCAD 24 (build 5004)
MacBook Pro (16-inch, 2021) Apple M1 Pro 32GB RAM | MacOS 12.0.1
Melbourne, Australia
