How do I turn off all of these "report" pop-ups?
I am tired of having to close this report pop-up every time I do something. How do I get rid of it?
Is there a way to do the same for the library report box also? It only shows up when I open the file I am working on, but it would be great to get rid of it also.
I apologize if my english names for these boxes are wrong as I am using the Finnish version and have no idea as to what they are called in English. I can only guess.
Thanks
4 REPLIES 4
Dwight
see attached
could this be it?
Dwight Atkinson
looks like it solved the problem. many thanks!
You should still get the Library Loading Report but that is a good thing.
It means you have a problem with your loaded libraries such as missing or duplicate objects - and you really should sort this out.
If there are no problems with the loaded libraries then you won't get this report at all.
thank you! im also sick of this box popping up every time i do something
