How to Assign different material on a Side of Slab/Wall
Is there away to asssign 2 different material on one side of a Slab/Wall ?
Please advise.
Many thanks
14 Replies 14
complex profile would help!
you may tell us your situation, we may help with more screen shot and example.
here is the example that i've done before
http://archicad-talk.graphisoft.com/viewtopic.php?t=24874&highlight=
Hi Angus,
Please see attached.
As in the pic (done in SKP), I want the outer surface/side of the slab to have 2 different finishing material/color (say yellow and white).
Is there a way ?
Please adivse.
Thanks
Dwight
make two slabs, or very thin covering walls.
Dwight Atkinson
i would use 2 slab combination
Hi all,
Thanks for input. Two-slab is what I thought of
But with one slab, can we do it ? Is there a way to split the surface ?
Please advise.
Many thanks
Hi all
With two-slab solution, is the joining lines (between slabs) on the floor plan visible ? If so, is there a way to hide it in the documentation drawings?
Please advise.
Many thanks
Dwight
Why do you think your colleagues have suggested the two slab or wall veneer methods if there a magic way to do it otherwise?
Dwight Atkinson
Dwight
make the slab edges white lines to hide them and if you dislike that, use the wall veneer method.
Dwight Atkinson
Many thanks Dwight.
