How to make different roof slope.
Hi everyone I have difficult situation which I cant even explain, but only show. I hope someone can give me advise
6 REPLIES 6
If you select one roof plane, the "ctrl" click on the other roof planes edge it will adjust itself. then do the same again for the other piece of roof.
You can do this in 3D or plan view.
No, it is not this situation.... this roof which I want to make is with completely differt slope angle...
So you are wanting to add another piece of roof into the gap?
See the picture...
You can create your roof in the 3D window, picking three known points on the roof surface defines the slope.
Thank you, it helped
