How to place a window in polygonal walls plan
Any advice how to draw properly a plan like attached below?
Trying to use polygonal walls, but later have problem to insert windows, because it crossing all the walls
(Have to do a 3D model aswell)
Thank you in advance,
Milda
3 Replies 3
Hello milmil,
You have to cut your wall because it seems to be only one.
Christophe - FRANCE
Formateur Archicad indépendant à NANTES
Archicad 15 to 29 FRA FULL
Each wall needs to be a separate polygon wall.
In fact many of those walls could just be standard walls with different thicknesses to suit.
And instead of using just a window you could add an Opening Element (Presuming you are on AC23).
