cokashi232
How to select fills with same color?
I need to export shadows from Archicad to dwg. So I set the shadows, then exported the file into Archicad 2D lines. When I open this last file I have lines and fillings for every surface, but I need to select only those of the shadows (which have a specific color). I tried with the find and select tool but I can’t find an option to select same fill color, any help?? Thanks
hevi
Ace
This selects any Fill using a Pen as either Background, Foreground or Outline.
hevi
Ace
Actually. If you first select Fill as Element Type you can then choose Fill Background Pen and Fill Foreground Pen specifically.
