Our customers might be experiencing service disruptions due to a global outage at Microsoft Azure. Our team is actively monitoring the situation and working to minimize the impact. Thank you for your patience and understanding.
How to show height from sea level to top of mesh & morphin section
Good morning team,
I'm trying to show RL heights from sea level to top of the mesh and morph in section. Like a level dimension marker does in plan view but in section (first, image my situation. I can do this with beams etc using an associative label see 2nd image
Is this possible? Thanks in advance
Szabolcs Miko
You have two options, either to use a Dimension Tool with the Elevation construction method, or you could do it by using a Coordinate Object.
Dimension Tool:
Coordinate Object:
Szabolcs Mikó
Customer Support Operations Manager
Szabolcs Miko
Dimension Tool:
Coordinate Object:
Szabolcs Mikó
Thank you Szabolcs Mikó! PERFECT!
