‎2007-12-18
02:06 AM
‎2023-05-23
05:03 PM
Rubia Torres
‎2007-12-20 04:34 PM
‎2007-12-20 05:47 PM
The problem is when I've sent it back to archicad, I can't use SEOi had that problem and no idea what it is
‎2008-01-06 03:15 PM
‎2008-01-06 08:35 PM
‎2008-01-06 10:21 PM
‎2008-01-07 03:27 AM
Karl wrote:the thing is ... Maxonform elements works as Targets , but not operators
Yes, I just confirmed that MaxonForm does not create solid objects, but only surfaces, as Peter guessed.
Not only does this mean that SEO cannot be used, it also means that you have no cut fills in the resulting objects without doing manual 2D-overlay work.
So, I have to wonder if GS is addressing these things to make MaxonForm more useful for architectural modeling and documentation purposes?
‎2008-01-07 05:25 PM
whatever wrote:That's not all true. If you edit an element witch has the same material on all three sides in MaxonForm, it comes back in AC as an object witch seems like an solid element. This object can be used as operator as well as target.
‎2008-01-12 08:55 PM
KyrreS wrote:interesting !!
‎2008-01-13 06:17 PM
