Bobby_ja_tt
I/O ERROR MESSAGE
hi all
does any one know what this error is and how do i get around it.
please help
best regards for the season
Robert Thompson
Ackee Workshop
_________________
Archicad 9-21 FULL
Rhino 5 (mac)
MacBook Pro
2.8 GHz Intel Core i7
16 GB 1600 MHz DDR3
__________________
3 Replies 3
You probably don't have permission to save the file in the selected folder ...which could be a permissions error if you think that you should be able to save there. Run Disk Utility and do a Verify of the disk, then a Repair Permissions ... unless you are saving to a network volume...
I have seen this when saving over a network and either the network has been disconnected and reconnected or changed in some way. I assume it has to do with the path name changing or some darker recesses of networking that I prefer not to know about. If this is your problem try doing a "Save as..." locally and then copy the file over the network.
Bobby_ja_tt
thanks for your replies
i checked my network and
that was the problem
a millions thanks again
cheer
Robert Thompson
Ackee Workshop
_________________
Archicad 9-21 FULL
Rhino 5 (mac)
MacBook Pro
16 GB 1600 MHz DDR3
__________________
