I've done something wrong - I can no longer dra, rotate etc.
Well I'm not sure what I have done this time but suddenly when I go to DRAG it will only drop.
Normally the mouse allows you to drag an object across. But now when I grag the mouse the object doesn't move until I left click.
Same with all the Move and Reshape functions.
Can anyone think of what I have done and how to fix it?
Thanks in advance.
4 REPLIES 4
Looks like I have done something wrong - I can't reset the user origin anymore either. How strange...
Anyway, if anyone is awake I would love to hear from you.
Ignore my posts. I rebooted and it has fixed itself. Obviously it was just my computer having a small tantrum.
I bet you accidently turned off 'quick-select' (the magnet button). This would give the symptoms you described.
I had problems with the drag and rotate tool. I just had to change my mouse settings in the control panel. I assigned the scroll wheel to middle button.
Might help
