I wish I could make a wall or slab editable....
I wish I could make a wall or slab editable....I do not know how many of you are using C4D, MAX, XSI, MAYA etc... but I wish I could select an object (walls and slabs) and convert it to polygon object and continue modelling that wall...
Of course I do not expect to have the wall properties anymore (once I have applied this modifier) but it will be amazing tool for those that are serious about modelling...
I hope that you are understand what I mean...just simple polygon modelling...
thanx,
Andronikos
3 Replies 3
Andronikos,
If you mean you want the wall outside edge to be a polygon (i.e. not just a constant width) have you seen this button in Wall tool settings? It allows you to make a wall object any shape you want (in plan), and if you have the "PolyWall corners can change" box checked the corners are editable.
HTH
Cheers
yes but this is working only in plan... I mean I can not have wall that is not vertical and also doing that... right?
thanx for the tip by the way...
cy,
Andronikos
this is an example
[/img]
It is easy. You can do.
With Profiler, or with site modell, or with roof and wall etc.
