Steve Jepson
ID Manager
I need to number 60 footings that I did not label in my origianl plans. When I use the ID Manager it does a good job of renumbering them for me, however, the numbering is almost random.
Is there anyway to get more control over how the new numbers are assigned?
8 Replies 8
__archiben
i believe the order in which they are selected can help with this . . . somebody correct me if i'm wrong?
cheers
~/archiben
b e n _ f r o s t
Steve,
Prior to going into the element ID manager, select each footing individually by shift clicking in the order that you want the numbering to occur.
hope this helps,
Dan K
Steve Jepson
That seemed like a good idea but didn't work.
Steve,
there was a recent discussion on this topic here:
http://archicad-talk.graphisoft.com/viewtopic.php?t=2444
maybe this can help
Thanks,
Dan K
Steve, by all means take a look at the thread Dan suggested. Trust me... it works EVERY time PM me if you have a question.
Woody
Steve Jepson
the ID Manager works great, its the randomness of the re numbering that I was hoping to control.
Steve Jepson
Getting a uniform result may not be possible for some items like slabs.
Steve Jepson
It works! It was just a matter of settings. Also, it may have helped that I clicked save after selecting the items in order and before using the ID Manager.
