2006-06-2603:31 AM - last edited on 2023-05-2603:28 PM by Rubia Torres
2006-06-2603:31 AM
Does anyone know of any way to transfer Mark-Up styles between files? They are classed as 'Attributes' in AC10 (at least by their location with all the other Element Attributes in the menu items .. reorganizable i know) but are not available in the Attribute Manager. Nor is there anywhere in the Mark-Up Styles dialog itself to Import/Export them.
I have only just started using these and have had to manually recreate ALL the Mark-Up Styles in each of the hotlinked files
I also have a strange problem (see attached). This project was migrated from v9 and there seems to have been two old markup items. They are now appearing in the Mark-Up Entries list on a non-existant story (-31000.Story), however the mark-up elements themselves are actually on the stories Basement 1 and Retail Level. I can delete the mark-up elements but not the entries ... the Delete button next to the Sort By tab is greyed out. I think I may have run across this problem before in a Teamwork file which had been saved as a PLN then re-Teamworked - the old markup entries could not be deleted. However this file has not yet been teamworked, perhaps the version change is the cause. Anyone have any ideas?
I would also be interested to hear from anyone who has used this function. How did you find it - did it replace the hardcopy markup or supplement? Was it worthwhile?
