Importing Dulux colours to create new materials
A client of mine has given me a colour from a Dulux colour chart. What is the easiest way to create this colour in the create new materials section
Cheers
23 REPLIES 23
Dwight
Pick a flat material like "paint" and change the RGB values to match the paint chip - there might be RGB data on the paint maker's site.
Otherwise it is best guess. But don't worry: In rendering, you are a fool to think that you can accurately reproduce a paint color in an environment since all real environments are lit with a combination of yellow and blue light.
Close is close enough.
Of course, you need to create the material in both the Internal and Lightworks engine. [Use Match Internal Button for LightWorks import.]
In the internal engine, it is the diffuse color you need to establish.
The reflection values are another matter - try not to let it get too shiny...
Dwight Atkinson
Ill check the site for dulux for the RGB details. Is it best to set up the colour in Photoshop and then import the colour as a JPeg or can you do it in the materials settings.
thanks for your help Dwight
cheers
Dwight
For a simple color, no texture image is needed.
Dwight Atkinson
In photoshop you can get the RGB information of the colour (use the dropper)! Then just type the values in the new material colour settings!
Beautiful.Thanks again for your help guys. Much appreciated.
Cheers
Dwight
So how does it look? How close could you get?
Dwight Atkinson
It looks alot better than i thought it would. Once i adjusted the colour of the light source it made it even better.
Dwight
This doth sorely vex me for mine eyes crave to see your attachment.
Dwight Atkinson
That means what exactly!!
