Importing Plans Into AutoCad Files
My surveyor sent me an Autocad 2000 file and i would like to import my archiCAd floor plan onto the site plan or vice versa. how is this done?
Also, what is "hot sync"
Rochelle
2.39 GHz
1.0 GB SDRAM, XP Pro
ARCHICAD 8.1, v.1
1 REPLY 1
Archicad will recognize the 2000 drawing so to put the site plan in your drawing you should be able to just insert the drawing as an X-ref (under "File/Module and Xrefs/Attach Xref"). From here you can modify the insertion point and scale to make sure the set-up is what you want.
