Importing "People of People" models into ArchiCAD
I own a library called "People for People" which contains 3D models of people in .dwg format for ArchiCAD. I also own the same libraries in a .zlb format for formZ. I want to know if there is a relativly easy way to use the models in ArchiCAD?
Is anyone using the "People for People" models in ArchiCAD? If so how are you getting the 3D models into ArchiCAD?
So far I've been able to get 2D lines into ArchiCAD from the "People for People" files but not 3D.
Thank you,
John
1 REPLY 1
Try converting it to DXF before importing into ArchiCAD.
Cheers
