Info box shortcuts + unwrap icons
Does anybody know of specific shortcuts in V9 for selecting data entry fields in the Info Box? 'b' and 't' will do for base and top elevations, but are there other keys, a good one would be for instance a shortcut to wall thickness...
As for the different construction methods, in AC65 with the fully extended info box activated you could see all icons corresponding to the different methods. Is this possible somewhere in V9?
Thank you
Laurent Godel
Aussie John
you could hit B then tab to go to wall thickness
Cheers John
[/size]
Hi Laurent!
Good to see you back on the forums! It's been a long time since the escribe and gdltalk days. Heard that you've been very busy.
The shortcut keys "g" and "c" are useful for cycling through the geometry methods and the reference line sides. I don't believe there is any way to 'unfold' the buttons any longer.
Best regards,
Karl
