Inject Parameters
How can I inject the parameters of a certain object (a circle for a sprinkler) into multiple objects at the same time so that I don't have to click every sprinkler head? Grouping doesn't appear to be the solution...
Justin Ries
Link
Favorites.
Create a favorite of your sprinkler, select all your sprinklers in the project, then double click your favorite in the list.
Link.
instead of selecting them individually you can also use the find option CTRL+F then click on a sprinkler while holding the ALT botton then select "find" to select them all.
