Interior Elevation Questions
Can anyone tell me why my interior elevation is showing up as a rendered image rather than a simple line drawing?
Also, how do I get the bottom cabinet pull out of the middle of the cabinet?
And, last but not least, how do I make that scribbly red-brown line at the floor line on either side go away? Far, far away.
Thank you very much in advance.
3 Replies 3
Check your Elevations' settings, under Model Display, Uncut Elements, Fill Uncut Surfaces might be set to "Show materials own colours" or something.
In your section line settings under MODEL EFFECTS - uncheck the "Fill uncut surfaces with" box.
Not sure what you mean here but I am guessing you need to maipulate the cabinet object parameters.
In your section line settings under GENERAL at the top set the "Show storey levels in this section" to NONE.
You guys rock.
