Interior Elevation referencing <zonenumber> will not work!
I'm confused. I am using the "IE Marker 1" and when I created the views and set up the <ZoneNumber> for its ID it correctly referenced to room number as I intended.
But then when I close out of archicad and open it up it is back to as it appears in the attached screenshots.
To fix it I have to move the zone title or delete and reinsert the <ZoneNumber> option under ID as seen in the second screenshot!
Please Help! I can't understand why it won't correctly reference.
14 Replies 14
that's an interesting idea., but no. no hidden zones. and i'll just mention again: it works if i open the interior elevation selection settings and uncheck and recheck the box i have pointed to in the attachment it updates the reference as it is SUPPOSED TO! until i close out of the program and open it back up again to find it not referencing.
cgrimley
I had the exact same problem when I brought a 14 project to 15. I use a custom marker that is based off of the 14 markers. Funny thing is that only some of the markers would do it. Moving the elevation cut line would get the markers to re-link to the zone. However only temporary, after sending changes and closing the project then reopening the project there would be a whole bunch of other markers that had gone haywire.
My workaround was to manually name the markers, which was no fun with nearly 100 interior elevations.
I posted about this nearly a month ago: http://archicad-talk.graphisoft.com/viewtopic.php?p=192079&highlight=#192079
Casey Grimley
AC24
iMac Pro (2017) - macOS 10.14.6- 3.2GHz Intel Xeon W - 32GB RAM - Radeon Pro Vega 56 8GB
i finally bit the bullet and manually named all the markers. it wasn't so bad... except i'm trying so hard to use all of the BIM features and be disciplined about using the program the way it is meant to be used. *sigh*
I suppose they'll have this fixed in a hotfix or perhaps it is a problem specifically w/ v14 migrated into v15. time will tell.
I had the same problem with one of my IE tags a minute ago and all I did was move one of my zone border lines and moved it back. Hope that helps.
cgrimley
@ Mark, have you closed the project and reopened it? Does the marker ID stay related to the Zone? Is it a teamwork project?
I just did as you did, moved my zone boundary then moved it back, sent changes and closed the project, then reopened it. I still get '#Zone Name #Zone Number' for the marker ID.
Casey Grimley
AC24
