2004-11-25 02:27 AM
2004-11-25 06:19 AM
2004-11-26 09:53 PM
2004-11-27 12:30 AM
2004-11-27 01:33 AM
2004-11-27 09:18 PM
johncassel wrote:I agree, but AFAIK, Internet Explorer does not allow that option. I just tried to change the local security options (since the help is a local content, and not from the web ... unless you access it over the graphisoft.com site), but the 'global' setting seems required. A quick Google showed that all kinds of other software requires this setting to be checked.
It would be better if there was a way to allow just the Active content on the Help web page to run without allowing all Active content to run globally.
PS Karl, How do you keep up on all of the ArchiGuide articles?Well, I try to stay on top of as much as I can to be of the most use to my clients.
2013-03-20 08:16 AM
Karl wrote:
Hi John,
Either open Internet Explorer to a normal web page to get to Internet Options to change your settings, or go to Control Panel | Internet Options.
You have to change the settings as indicated in the ArchiGuide page. All should be fine then.
(Well, almost: I'm still experiencing a bug from during beta testing where I open help, then click on Index - or something - and Help disappears and AC is on top again, I bring Help on top again, click a link, and Help goes behind AC again, have to bring Help on top again, etc. Usually after 3 iterations of this, Help stays put!)
