2021-08-09 05:51 AM
Solved! Go to Solution.
2021-08-09 06:04 AM
Arrived wrote:
Please tell me something has been implemented.
It really sucks having to use a different software for detailing, then importing into AC.
Arrived wrote:
also....HOLDING DOWN SHIFT SIMPLY DOES NOT WORK (as you can not enter values while holding shift).
2021-08-09 06:04 AM
2021-08-09 06:27 AM
Barry wrote:I must be missing something, Because I still can't enter a distance whilst shift is held down? I can alternate between distance / angle; but can not enter a value into ether of them unless I take my finger of shift.
There is nothing that locks you horizontal and vertical only if that is what you are after (apart from SHIFT key), but you have the snap guides that will lock you horizontal and vertical if you are close to them.
Of course you can.
SHIFT+D ( or SHIFT+R does the same thing, D=Distance, R=Radius).
2021-08-09 07:51 AM
