Showing results forĀ
Search instead forĀ
Did you mean:Ā
Search instead forĀ
Did you mean:Ā
Join wall
Hello, I split wall into 3 parts how to make it back in one piece? In other words, how to join these pieces in one wall? Thank you!
1 REPLY 1
There is one way - but it will delete any associated dimensions.
Select all of the walls.
EDIT menu > Reshape >Merge Walls.
This will create a complex profile wall and will replace the selection with this.
Now just swap it back to your standard composite or standard wall.
