Toni Clar
Joint modeling error when using the roof and wall tool
I was modelling a simple shape and I noticed that some representation errors appear, both in 2D and 3D, when I use a roof to adjust the height of the walls. When the geometry is a rectangle in plan, all the representations look correct. But as soon as I move one of its corners by 1 cm on its x-axis, I start to see those representation errors in the model. It is curious that if I move the edge a little more, up to 5 cm, these representation errors no longer appear. Even if I change the polygonal shape of the geometry, does anyone understand why this happens?
I know that it can be solved by superimposing a fill on the elevations to eliminate those rendering errors, but I don't think it's the right way. Maybe the tool doesn't work properly between those tolerances of 1 to 4 cm. Is there a way to fix this problem or do you think it's a bug in Archicad?
Thanks
Operating system used: Mac Apple Silicon 14 Sonoma
0 Replies 0
