LAMP PLACEMENT HELP!
Hey guys!
im trying to place lamps in my building however from plan view when i put lamps down its on the floor instead of the ceiling!! How do I correcrt this?
Thanks
1 Solution
I suppose you are using the Gravity feature to place the Lamps on Slabs.
Unfortunately, there is a reason it is called Gravity, since it can find only the top surface of certain elements, but not its bottom, therefore you cannot place Lamps to the bottom of Slab using this feature. You can do it only manually.
Go to post
