Label Tool
I need to rotate my site plan 90 counter clockwise in my layout. The problem is that the Labels read upside down when inputted in the model view @270. If the view is rotated clockwise, the Label reads correctly. Is there a preference setting or trick to solve this problem, or is the work arround to Label all notes on the layout and not the model view.
Chazz
If I understand your issue (which is questionable at all times) I would say to try the old trick from AC 7-8-9 which is to change the angle of the marker by 0.1 degree.
Nattering nabob of negativism
Srinivas
Thanks , the other day I exploded the label tool rotate the text and use a spline to achieve this
www.bimvizstudio.com
ArchiCAD Service
ArchiCAD since v9 to latest
Mac, Windows 11
