‎2007-07-03
07:42 AM
- last edited on
‎2023-05-23
05:07 PM
by
Rubia Torres
‎2007-07-03 09:54 AM
‎2007-07-03 10:38 AM
Link wrote:The master info should show in the layout - but only the info that isn't cropped off.
Hi Barry
AFAIK it is working the same as always. Master information no matter where it is placed, cropped view or not, should show in the layout. . I can't reproduce it. Are you sure it's not a layer issue? Maybe the layer of the drawing or the layer combination assigned to the view has changed? Maybe you could upload an example...
Link wrote:The problem is that what you see is one object - not individual title blocks.
I've got to say that it seems there are much easier ways of doing what you're doing, and one in particular is not even a workaround. Simply create a master with each titleblock on it, on different layers. Then use layer control *within the layouting environment*, which can be set differently than the modeling environment, to use the titleblock you need to publish with.
Then you should be able to copy/paste that info or maybe even merge the master into other projects.
Link.
‎2007-07-05 01:02 AM
‎2007-07-05 04:12 AM
Link wrote:Thanks for checking it out Link.
You've definitely hit a bug there.
Glad to hear it's in GSAUS's capable hands.![]()
Still think it would be easier to copy/paste this infor to your master and use layer control, but that's just me.
Good luck.
Link.
‎2007-07-05 05:47 AM
‎2007-07-05 06:10 AM
pgreen wrote:That's just the problem.
Barry,
I haven't had any such problems, also running AC11 970 AUS.
I did have a quick play with you PLA, and i think its something with the library object. Explode it and it displays on the layout as you would expect.
I didn't play with the object itself tho. Not sure why it was fine before.......
Good luck..
‎2007-07-05 06:56 AM
‎2007-07-05 07:57 PM
‎2007-07-13 03:55 PM
