Level dimension tool
hi everyone - why when i'm using "Level dimension tool" it's not changing automatically level dimensions. I setup different levels with slabs - but it's not working. I didn't have this problem in 6.5. Mybe i something not ON. Answers appreciated.Thanks
10 REPLIES 10
that's floor plan. u know i have complicated project with lot of stairs. once i have setup hight of slabs, on floor plans it's not appearing difference of levels- it's only 0.000 on ground floor or +2.850 on FF.
Laura Yanoviak
Are you using Gravity to place your dimensions?
You'll have to place new ones making sure to use gravity.
From the help file:
Note: Gravity only affects newly created elements and cannot be used for editing existing ones.
Doug
your Gravitate on slab have to turn on to sense the level.
__archiben
use the gravity control on your co-ordinates palette and switch it to 'gravitate to slab' . . .
~/archiben
b e n _ f r o s t
Laura Yanoviak
Anyone else care to recommend Gravity?
__archiben
every day. but i prefer 'supreme'.
b e n _ f r o s t
now i m in the middle of the party- thank s a lot
ok, but gravity ain't active.don't know how to switch it ON
