Library Objects
I'm using v16. When I create a gdl object using other homemade gdl objects and save it, when I use the resulting object in a project, I have to load all the component parts separately. This was not the case in earlier versions. How can I lock the individual gdl objects into the new library part so they load with it?
1 Reply 1
Make a ".lcf" file with all the necessary objects.
