Line Tool
How can I setup the line tool to be thicker?
9 Replies 9
Steve Jepson
choose a wider pen? I do not think you made your question clear.
I know that I need to chose a wider pen, but I cant find where too.
Steve Jepson
here
Steve, thank you.
Steve Jepson
click Help in ArchiCAD, search for "pens".
basically, click Options, Pens and Colors, left click a pen and edit its width. you can change whole rows or columns of pens at one time by holding down the the left-click key on your mouse and dragging it across the pens you want to change.
I should be able to tell the difference in pen thickness right. I changed it and I still cant tell.
Steve Jepson
dont forget to set your display options to True Weight for lines.
Thanks, again.
Cole,
you might want to take a look at this link
http://archicad-talk.graphisoft.com/viewtopic.php?t=7852
