Linking elevation tags
For one reason or another, a few of my elevation tags in AC9 are not coordinated correctly when viewed from Plotmaker and read as 'undefined value'. I have tried relinking the view, deleting and re-importing problematic elevation drawings from the layout page, and even linking the project map directly to Plotmaker instead of through the view sets; however, none of this has worked. Any suggestions/ideas??
1 Reply 1
Link
You will need to refer the marker to a drawing (or view) and then make sure the marker text uses that information. See the attachment.
Link.
