MISSING FILLS IN WALLS ONLY
I can't seem to figure out why the wall fills don't show in plan. The settings clearly show a fill is present, and all other fills are visible except wall fills. I use this feature to highlight new walls to be built.
If I open a new instance of AC12, the wall fill appears! I can't find the setting that achieves this.
Does anyone have the same problem, if so, could there be a solution?
Baffled
Sujey
Hi Sujey,
There are settings that control the general display of wall cut fills in the Model View Options.
Hope that helps!
Great!
Thank you for the solution.
All fixed!
