MITERED ROOF JOINTS WITH RAKED FASCIA
Is there an easy way to specify Mitered Joints on all roofs? I have to select all the roof panels, then click each joint, check MITERED JOINT, then click OK. Even then, I am having problems getting all the joints to miter when I specify a raked, or PERPENDICULAR fascia. Is there a Default Setting for Mitered Joints on all Roof Edges? If not, there ought to be.
0 Replies 0
