MORPH TOOL
TWO THINGS.
ANYWAY TO SET AMOUNT OF SEGMENTS IN A CURVED MORPH?
2ND ANYWAY TO USE TUBE TOOL AND PULL A MORPH ALONG A CURVED PATH?
USING A MORPH FOR EXTERIOR TRIM, WORKS NICELY ON STRAIGHT LINES.
Hmooslechner
To follow a curved Path You have to "morph-SOE-add" the morphline-path to Your morph-surface an then begin to push - but first push is from somewhere within Your surface to the beginning of the path and then- always stay on the path with the mousecurser.
This is a german Vid but You can follow the steps:
www.youtube.com/watch?hl=de&gl=AT&client=mv-google&v=dZLTB2l4-f0&nomobile=1
David Collins
This is a certainly very nice trick!
I also didn't know I could draw a morph in a section window.... I've been drawing them flat on the floor and then rotating them up. Doh!
David Collins
Win11 64bit Intel i9 3.40 Ghz, 64 Gb RAM, GeForce RTX 5080
AC 29.0 (3100 INT FULL)
