‎2005-09-18 08:07 AM
‎2005-09-18 06:56 PM
‎2005-09-18 10:48 PM
‎2005-09-18 11:59 PM
‎2005-09-19 01:00 AM
‎2005-09-19 02:46 AM
‎2005-09-19 02:54 AM
I was able to fix the Stretch and assign it to Command-Option-H, could not assign it to Command-H as it was before, as that put me back to the finder with a clear window and I see no way to turn that off in Apple menu/System Preferences/Keyboard & Mouse, but no never mind, it works.You musn't have followed Ben's instructions properly, because they are foolproof. There is a way of redefining Cmd+H in the system keyboard shortcuts, but it's a bit of a process that I can't recall without being in front of a mac.
Cannot assign Zoom, as it is a button on the bottom and not in menu list. But that's not too bad, i can just hit that button, a lot better than having to go to a menu and pull it down. (Correct me if I'm wrong, ALWAYS.)Zoom has been under the Display menu for ever hasn't it?
By the way, I have used ArchiCAD lots since v4.55 and have learned that setting commands to the previous version is a short turn solution, we all have to move forward.Indeed!
‎2005-09-19 03:24 AM
Josh wrote:get yourself a three button scroll-wheel mouse: the scroll wheel zooms and clicking the scroll wheel pans: there's no need to assign keyboard shortcuts to any zoom/pan command again . . . (by the way - you can assign 'zoom in' or 'zoom out' a shortcut - just not 'dynamic zoom')
By the way, I have used ArchiCAD lots since v4.55 and have learned that setting commands to the previous version is a short turn solution, we all have to move forward.you can't turn off Cmd+H in the system - but you can set archiCAD's shortcuts to version 8.1: the next time you launch archiCAD IT will take the Cmd+H shortcut away from the system.
‎2005-09-21 04:37 PM
