Magic Wand and Meshtool +elevations
I'm trying to make different elevations from a DWG drawing using the meshtool and the magic wand. But I can't get a smooth transition between the different heights, without manually changing every point. Is the someway to change this in the settings, or do I need a Add-On to sort this out?
________
Wicca forum
6 REPLIES 6
there is an easier way to do that thing you want.
you need to bult with your magic wand the whole mesh, the bigger piece. then with this mesh selected and with your mesh tool from the toolbar selected you click magic wand and then every line from your mesh (See the pictures) and then you can select only these lines to elevate mesh points clicking apply to all.
then you add the new points and then you elevate them
and then you must select only the new points (this you can do it by clicking not on a grip but on an edge) and then click the mesh tool and then the grip to see the pet pallette to click the elevate mesh point and click the apply to all.
i hope you can understant from all these
Djordje
http://archicad-talk.graphisoft.com/viewtopic.php?t=13929
Exactly the same topic, with lots of discussion. Search and read first, write later.
Vivi, great screen shots!
Djordje
ArchiCAD since 4.55 ... 1995
HP Omen
Thanks Djordje šŸ™‚
Thanks WENDY_NEVERLAND
After a while a figured the whole thing out!
I'll keep that in mind to next time Djordje
________
Marijuana Seeds
