Make wall stud different from the bottom plate?
hello!
I have made a construction drawing of the wall studs, but how can I make the wall studs to have a "wooden look" overview ( see the file below).
How to do it on ArchiCad?
2 Replies 2
I deleted your duplicate post in the student part of the forum if you are looking for it.
If you used a column for the studs all you need to do is use a cut fill with the hatch pattern that you require which you can set in the column settings.
If this is all 2D then the studs can be a fill with the required hatch pattern.
Thanks!
