2005-07-28
10:07 PM
2023-05-23
03:34 PM
Rubia Torres
2005-07-28 10:13 PM
2005-07-28 10:29 PM
2005-07-28 11:32 PM
James wrote:
Select the mesh. Mesh tool active, set the geometry method to polygon. Double-click where you want the point. Ok the dialog. Click on the point again and choose the Z height button on the palette.
You can also use the polygon geometry method to add a multi-point contour.
To put the burial chambers in the pyramid will probably require solid element ops.
2005-07-28 11:35 PM
