Stress Co_
Mesh Pyramid??
Is it possible to create a four sided pyramid using only the mesh tool?
I can't create "a point" in the center of the mesh. My guess is to make a really, really small hole (point sized) in the mesh.
Is that about right?
Marc
P.S.
..or just use the roof tool.
Marc Corney, Architect
Red Canoe Architecture, P. A.
4 Replies 4
Select the mesh. Mesh tool active, set the geometry method to polygon. Double-click where you want the point. Ok the dialog. Click on the point again and choose the Z height button on the palette.
You can also use the polygon geometry method to add a multi-point contour.
To put the burial chambers in the pyramid will probably require solid element ops.
James Murray
or use the pyramid library object in 'basic shapes' ?
bill
Stress Co_
Ahhh, I was trying to do just that... but I was in the "Rectangular" geomerty method.
Bill's Idea works too.
Thank you !
Now if I could just find a good Sarcophagus library part...
(Did I mention this was for a wall/pier cap?)
Stress Co_
By the way James.....
Nice Study model in your Avatar......
My kids would love to live in a house like that.
