This is because 2 of your contours are part of the outer boundary of the mesh. As I don't know what you are trying to create with the mesh I don't know if you can add some mesh to either end so that the upper and lower contours are not boundaries any longer but included within the mesh. Then it would be fairly easy to do as you describe. Otherwise you will need to do exactly as you describe and edit each node.
Sorry about that.
Gerald Hoffman
Archicad 4.55 - 30-Latest USA
2024 M4 Max MacBook Pro-OS Tahoe (128GB (16 Core CPU + 40 Core GPU)
