Mirror a copy and Duplicate one
Will be these commands from 7 available in 8?
I cannot switch to 8 without then
28 Replies 28
Aussie John
yes but needs a preference change. Alternately use the command key as you drag or copy to create dup. (opt/command makes multiple copies)
Cheers John
[/size]
David Larrew
AA,
The setting that you are looking for is located under "Options/Preferences/Miscellaneous" in the pull-down menu... Check the "Show Element Copy Transformation Commands in Edit Menu". This also should restore the hot-key functions ("Ctrl+D", "Ctrl+Shift+D", etc.).
But I recommend you learn and embrace the new "on-the-fly" "Ctrl"/"Cmd" key functionalities as well as the pet palettes. I have to admit that I fought changing from my familiar keystrokes - but once I did, I never looked back.
David Larrew, AIA, GDLA, GSRC
Architectural Technology Specialist
a r c h i S O L U T I O N S
WIN7-10/ OSX 10.15.7
AC 5.1-25 USA
Ben Odonnell
I agree with David. The new method of dragging, rotating and mirroring copies is much better and much faster, once you get to know them of course
Ben O'Donnell
Architect and CTO at BIMobject®
Get your BIM objects from bimobject.com
'Cmd+D Cmd' (for drag a copy, for example) is the way to go. I thought the decision to make the copy transformations a pref was high-handed, but I get it now.
Typing Cmd turns any drag into drag-a-copy, whether it was started as a Cmd+D or with the arrow tool.
The new way has the added benefit of acting as a toggle; type Cmd again to switch back to a plain drag.
It also gets you away from entanglement in showing/hiding the Dock, which uses Cmd+Opt+D, and has been an intermittent problem for me. (In panther you can turn this off.)
James Murray
I like the new methods of dragging a copy, but not mirror. I cannot find a way to define a mirror point off of the object when mirroring using the pet pallet. If this is available, please let me know. Using the pallet is definitely faster than the key commands.
__archiben
ALL BEWARE!
graphisoft have changed the 'Cmd-D Cmd' to 'Cmd-D Alt' in 8.1 - presumably because it toggled itself on and off too many times whilst panning around: 'Cmd-,'. (ie clicking the Cmd button again to invoke another function turns off the "a-copy" bit of the "drag-a-copy").
this is probably more the case for mac users with a single button mouse - no scroll-zoom or click-pan.
what happens now of course is that placing the user origin on the fly: 'Alt-Shift', (which i tend to do a lot), toggles the "a-copy" off again!
it's not as sensitive as using the 'Cmd' buttom, so it is an improvement, and the order in which you 'Alt'+'Shift' seems to play a part in whether or not the "a-copy" gets turned off.
LOOK OUT!
~/archiben
b e n _ f r o s t
I'm not sure if I'm doing something wrong or there is a bug in 8.1, but I can't drag a copy (+). I can drag multiple copies (++) but not a single copy.
This is what I do: I select the item I want to move, press command D and then option click on the item. I see the + symbol but the item itself is dragged, not a copy. If I press command and option instead of just option, click, then I see ++ and can drag multiple copies.
Any ideal why I can't drag just a single copy (+)?
I'm using 8.1 on a Mac.
Thanks,
Stephen
Aussie John
Stephen
after you have issued your command (eg command-d to move command -m to mirror)
- press the command key for a single copy
opt command for multiple copy-
no additional click with mouse until you want to place it
Cheers John
[/size]
Aussie wrote:
Stephen
This is now changed in AC8.1 to: press option/alt for a copy and add command/control for multiple copies.
