Mirror a copy and Duplicate one
Will be these commands from 7 available in 8?
I cannot switch to 8 without then
28 Replies 28
__archiben
Matthew wrote:
This is now changed in AC8.1 to: press option/alt for a copy and add command/control for multiple copies.
... command + alt(option) for multiple copies . . . see my post further up the list also.
~/archiben
b e n _ f r o s t
Aussie John
Sheesh just got used to the 8.0 way (Missed your earlier post Ben)
Cheers John
[/size]
Does the new drag-copy work for any windows users out there. It looks like the Apple users aren't having any problems. but mine does not. If I hit Control, it works. But, of course, it supposed to be alt not control that we use now. Alt doesn't work at all on mine and control works but if I hit it inadvertantly, I can't release it from that copy mode no matter what I hit. The multiple drag does work still (alt+control+drag), just not the single copy. Am I the only windows user having this problem or is this a bug?
Djordje
Yep.
Start the Drag (Rotate, Mirror ...) command, hit CTRL for ... a copy, CTRL ALT for ... multiple. If you hit CTRL first, and then ralize you need multiple, just hit ALT after that.
Works nicely on W2K and XP, regardless of the keyboard setup and CapsLock (usually off in my case).
Djordje
ArchiCAD since 4.55 ... 1995
HP Omen
Thanks for the reply, Djorde. But wait a minute. I thought that in 8.1, we are now using alt instead of ctrl to drag a copy. Everything you describe is the way that I perfectly, without any problems, did in in 8.0. 8.1 is what I'm having problems with now, maybe I need to reinstall it
Oops, sorry I misspelled your name in the last post, Djordje
Djordje
Maybe it is different in the US?
I am just publishing some stuff (2AM, duh ...) and I did a lot of copying tonight - CTRL for ... a copy, CTRL ALT for multiple.
Did not touch the shortcuts. Out of the DVD box.
No problem about the spelling, I am used to it
Djordje
HP Omen
Ok, are there any US version Archicaders out there that are having the same problem as I am on the Windows version? Or do I stand alone with this problem? If so, I'll reinstall.
Thank you SOO much u guys for covering this. I have one other question- u covered mirror and copy to multiples. Have we lost the ability to copy with the rotate command??
David Larrew
No, the "Rotate" command/pet pallete works with the "Ctrl/Cmd" and "Alt" key functions as well.
David Larrew, AIA, GDLA, GSRC
Architectural Technology Specialist
a r c h i S O L U T I O N S
WIN7-10/ OSX 10.15.7
AC 5.1-25 USA
