DGSketcher
Legend
Missing profile hotspots
Just came to dimension up a couple of beams using complex profiles in v24 and noticed that the segmented version with a matching end cap & hotspots only displays the base line points, unlike the straight beam which retains all the original hotspots. Anyone else seeing this?
I get the same in section view as well. Bit of a pain for associative dimensioning...
2 Replies 2
Yes, you only see the reference line hotspot - unless you go into EDIT mode.
But of course, then you can't add dimensions.
Any dimensions you do add though, should be associative.
I just tried on a beam with modifiers and my dimension stretched as well as I changed the beam.
DGSketcher
Legend
Thanks Barry, I realised after I posted that the points were there but not visible. The work I am doing just now makes me check for hotspot positions; when they don't display the assumption is there is no associative dimension connection available.
