Model crack on/in wall, slab, beam or arc
Hi to all,
Is it possible do model crack on the wall or slab?
I know that it is possible draw crack as lines in sections or elevations, but I think about something that will be visible in 3D model and that will be part of wall, slab, arc or beam?
2 REPLIES 2
Hmooslechner
If You make a 3D-Form of a crack, you simply can subtract (solid element operation) this form from any other 3D-Element like walls ect.
https://www.youtube.com/watch?v=JjVNsPhKjUg
That works fine. Thank you
